alembic array export
Hi folks,
I'm having a bit of trouble with exporting an array of integers to alembic. When i create an array on the geometry and export it to alembic and import it back into Houdini again, the array is changed to an integer with the value of 0. Even if  I fill in the attribute name in the ropAlembic node at the `detail array attributes`, it's converted to an integer again.
Is this something alembic can't handle or am I doing something wrong? I'm totally confused right now!
Hopefully somebody can help?
Thnx!
Edited by freax
  • 2 years later...
