bob_gnarly Posted June 22, 2019 Share Posted June 22, 2019 Hi everyone, Silly question. I'm parenting a lot of Geometry objects to each other but I want to access the parent's attributes inside a SOP. As far as I can tell the best way is to use an Object_Merge node but I'm trying to avoid having to manually choose the parent object by name and wanted to know if there is an expression that will automatically find the parent object name? So I imagine (in my simple way) that there might be an expression that gets the Parent Object plugged into the input of the Child Object. Thanks. Apologies for the simplicity but I've dug and dug and somehow I can't find any info. Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted June 24, 2019 Share Posted June 24, 2019 Sounds like you should be working in a SOP construct if you need the attributes that much. `opinputpath("..",0)`/OUT Just make sure you always have an OUT or similar designated output node. Otherwise you can go into python land find the display flag, but that is a whole different set of issues. Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted June 25, 2019 Share Posted June 25, 2019 You can use __display_sop__ or __render_sop__ in the path instead of the name of a real surface node name to have Houdini use whatever node has the display flag or render flag. Quote Link to comment Share on other sites More sharing options...
