daehuck Posted June 25, 2019 Share Posted June 25, 2019 Hi guys I'm trying to use rop file output node in for loop. I want to render multiple frame using for loop However It only renders last frame with rop file output node. When with file node's write mode, it works fine I need help. Any comments will be appreciated!! Thanks I attached hip file. Render Button is in the <rop_volume_texture1> node read smoke_39.bgeo at 'file1' node Questionfoorloop.hip smoke.39.bgeo Quote Link to comment Share on other sites More sharing options...
