catchyid Posted July 9, 2019 Share Posted July 9, 2019 [Houdini 17.5.173] I have solid mesh with holes in it. I use RBD Material Fracture to break it (concrete mode), however : 1) If I don't enable "Detail" option, it works correctly 2) If I enable "Detail" option, I get bad geometry? Seems like a bug in Houdini! Has anyone managed to find a workaround? The only workaround it to fracture massively and glue pieces but this is a heavy solution? Thanks, fractureTest_DeatilsProblem.hip Quote Link to comment Share on other sites More sharing options...
catchyid Posted July 9, 2019 Author Share Posted July 9, 2019 (edited) Hmm, usually I find solutions after I post Anyways, two workarounds that do work, either: use remesh or divide, and somehow automagically this fixes the problem... Actually No! The above solution works for simple geo, but for complex geometrical shapes it still fails. The solution that still works so far is convert to VDB then back to polygon, but this is tooo expensive and you need to have high vdb resolution to capture mesh details, so it's not practical! Edited July 9, 2019 by catchyid Quote Link to comment Share on other sites More sharing options...
micheloualuguez Posted November 7, 2020 Share Posted November 7, 2020 I had the problem too and i think i discovered why ! The cells points of the RbdMaterialFracture are generated from a volume, so with a geometry with holes, it doesn't work. But if you scatter points ( input points or from attribute) from the geo itself, no issue! Tell me if i'm wrong 1 Quote Link to comment Share on other sites More sharing options...
micheloualuguez Posted November 7, 2020 Share Posted November 7, 2020 it still says that "holes can make bad or missing geometry", but no cut planes output and no missing geometry anymore Quote Link to comment Share on other sites More sharing options...
