ftaswin Posted August 8, 2019 Share Posted August 8, 2019 Hi guys, Is there any way to access point attributes in crowd setup to tweak the ragdoll behaviour? popforce seems to break the whole thing and each agent is processed as a single point but somehow still able to run bullet sim in ragdoll state but with limited capability. Thank you C Quote Link to comment Share on other sites More sharing options...
manx151089 Posted September 18, 2019 Share Posted September 18, 2019 s@name = "piece_" + itoa(@ptnum); //Randomize Velocity float x,y,z,minX,minY,minZ,maxX,maxY,maxZ,sx,sy,sz,sminX,sminY,sminZ,smaxX,smaxY,smaxZ; //source min max velocity vector min=chv("minVelRandom"); vector max=chv("maxVelRandom"); //randomize min max velocity x = fit01(rand(@ptnum),min.x,max.x); y = fit01(rand(@ptnum*222),min.y,max.y); z = fit01(rand(@ptnum*333),min.z,max.z); //assign the same to force which doesnt work //v@force=set(x,y,z); //assign the random velocity to each bone which worked for me v[]@v_agent; i@myBones= agenttransformcount(0, @ptnum); for(int i;i<=@myBones;i++) { append(@v_agent,@force); } //Initial Spin Random vector smin=chv("minSpinRandom"); vector smax=chv("maxSpinRandom"); sx = fit01(rand(@ptnum*1000),smin.x,smax.x); sy = fit01(rand(@ptnum*1222),smin.y,smax.y); sz = fit01(rand(@ptnum*1333),smin.z,smax.z); //assign Spin Random in Torque v@torque=set(sx,sy,sz); //Oscilation Setup //In the below vex code the only value I have used in the simulation is the v@oscillation's Y component but the code also creates an array which is currently not being used /*vector oMin = chv("oscillationMin"); vector oMax = chv("oscillationMax"); vector oRandom = fit01(random(@ptnum),oMin,oMax); v@oscillation = oRandom; v@zeroOscillation = set(0.0,0.0,0.0); v[]@oscillation_agent; i@myBones= agenttransformcount(0, @ptnum); for(int i;i<=@myBones;i++) { if(i==30||i==32||i==1) { append(@oscillation_agent,v@oscillation); } if(i!=30||i!=32||i==1) { append(@oscillation_agent,v@zeroOscillation); } } */ //Create v_agent array and a vector array for oscillation of certain selected bone numbers The above code will create some custom velocity for the agents in sop level and then later you can use the v[]@v_agent in a sop solver to copy to the particular agents you need to apply it to. So basically what we are are doing here is defining random velocity and torque to a certain number of bones in the crowd agents. You should feel free to bypass the codes that you do not need. I have already bypassed the oscillation bit of the code for you. Cheers, Manishkumar Makhija Quote Link to comment Share on other sites More sharing options...
ftaswin Posted April 22, 2020 Author Share Posted April 22, 2020 Sorry for the late reply, thanks. Quote Link to comment Share on other sites More sharing options...
