Houdini on 4k screen
Valent
I have some problems using Houdini on 4k screen. Global UI scale in Preferences helps a bit.
1. But the size of 'shape_pallete' is extremely small. (you can try to find it on the picture attached)
2. When you're using 'switch node' the active connection is shown as a solid line while inactive as a dotted line, but in 4k they both look the same.
3. If the handle of any horizontal slider is at the far left position it is almost impossible to click/drag it.
4k.zip
