noumiere Posted August 12, 2019 Share Posted August 12, 2019 I have a snippet that scatters points on a grid and for each point, creates a unit vector Line comprised of two points that point at an object (in this case, a point). Everything works fine until I add the 'orient' attribute to the system. For some reason, it treats the rotation of all points as one and the axis is at the scene center. What I'm trying to do is have each point have it's own local rotation so that if I copy a geo to these points, they will aim at that object instead of staying upright. I've attached the scene file Thanks! line_Orient_v03.hip Quote Link to comment Share on other sites More sharing options...
wakimsan Posted August 12, 2019 Share Posted August 12, 2019 Hi noumiere, What I would do is create an orientation matrix(I'd prefer vops). If you use the vector you created pointing at your target: vector p = point(1, "P", 0); v@N = normalize(p - @P); I added it to the normal in this case. Take the cross product of an up vector {0,1,0} and @N. And normalize it. That's our X vector. Now do another cross product of our normal and our newly created X vector. Normalize it. That's our Z vector. The normalized @N is our Y vector. Add these into a "vector to matrix3". Take that result into a "matrix3 to Quaternion" and that result is our orientation. If you're using vops(like me); bind export "orient" as a vector4 attribute. Your cubes or lines should be pointing at the target while having control of their local orientation. Your line node direction might have to be changed to -1, depending on what you're after. I can upload a hipfile later tonight if needed. Quote Link to comment Share on other sites More sharing options...
noumiere Posted August 13, 2019 Author Share Posted August 13, 2019 (edited) Thanks a lot for the reply, Joachim. I have tried to implement what you said in a Point Vop and have attached it to the file. For some reason , the second point in the line does not seem to be oriented. Do you have any idea why? Could I be that my VOPs is incorrect? Thanks line_Orient_v04.hip Edited August 13, 2019 by noumiere spelling Quote Link to comment Share on other sites More sharing options...
wakimsan Posted August 13, 2019 Share Posted August 13, 2019 Hi! Vops looks correct, the problem is that the target point you're creating doesn't really inherit the orientation. You could create the orientation again and point it back to the origin point, but that seems unnecessary. What I would do is change your approach to creating that second point. Easiest way I can think of is to not create a new point at all. Instead move the origin point along the normal @P += @N*chf("distance_mult");. And merge that moved point back with the original. You can use an "add" node to create the line between the points if necessary. And if you resample all points should point the same direction. Quote Link to comment Share on other sites More sharing options...
noumiere Posted August 14, 2019 Author Share Posted August 14, 2019 Hey Joachim, your explanation made a lot of sense! I implemented your suggestions and removed the second point, instead I merged in the initial point. The issue arises with the Normals for the merged point, or maybe I'm not sure of where in the stream I should resample? line_Orient_Vector.hip Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted August 19, 2019 Share Posted August 19, 2019 (edited) starting from: line_Orient_Vector.hip you could add Attribute Transfer to the between scatter and merge to copy the normals from input2 (attributewrangle3). It works as long as the distance between the two points is less than the minimum distance of two scattered points. Otherwise you have to tie the two points together in a way, for example sharing the same value for an attribute, the resample each line. See attached file line_Orient_Vector.fixed.hipnc Also, see vex function https://www.sidefx.com/docs/houdini/vex/functions/lookat.html, which does that for you already Edited August 19, 2019 by AntoineSfx Quote Link to comment Share on other sites More sharing options...
wakimsan Posted August 19, 2019 Share Posted August 19, 2019 Hi noumiere, Looks like you merged the plain scattered points with the points that has the new normals. The scattered points won't really have any normal or orientation, so it won't give you the expected result. What you're after(as far as I understand it), is to have the same normal and orientation for all of your points. Which means that when we create our copy with the offset along the normal, we need those to have the same attributes. The only things I would change with your setup is the order; after the scatter do the wrangle and pointvop. Remove the line which offsets the points: @P += @N*chf("distance_mult");. Now create another wrangle after all these and add the offset line. This wrangle will create the copy we're after. Merge the output of this second wrangle with the output of the node before it. Now both copies of the points should have the same attributes. And finally copy to points. The line and resample is not necessary. It only proves that the setup works properly and allows you to add as many boxes with the correct orientation as you'd like. Quote Link to comment Share on other sites More sharing options...
