davidyannick Posted August 26, 2019 Share Posted August 26, 2019 I'd like to select corners points here, I've tried and my wrangle does not work Can you tell me whereis my mistake ? Thank you hdni_untitled.hipnc head.obj Quote Link to comment Share on other sites More sharing options...
anim Posted August 26, 2019 Share Posted August 26, 2019 first, you have typo in the first line:missing u in @ptnum secondly since you did polybevel before this geo doesn't really have corners with 2 neighbours as there is a tiny polygon strip going around the whole shape, if you fix the typo and bypass the polybevel1 it will work as expected Quote Link to comment Share on other sites More sharing options...
davidyannick Posted August 26, 2019 Author Share Posted August 26, 2019 2 hours ago, anim said: first, you have typo in the first line:missing u in @ptnum secondly since you did polybevel before this geo doesn't really have corners with 2 neighbours as there is a tiny polygon strip going around the whole shape, if you fix the typo and bypass the polybevel1 it will work as expected what a dumb I am :/ thanks for your help Quote Link to comment Share on other sites More sharing options...
