Changing Cd saturation with attribute expression
Hi everyone,
I'd like to be able to adjust the HSV via an attribute expression. What's easy is multiplying the point color with something like this: "value * fit(float(rand(@elemnum)),0,1,0.5,1.5)"
However, just using that expression multiplies the color with a random number giving a generally blacker/whiter color.
What I would like is to be able to change the saturation separately. The result would be a set of X wires having the same color with a saturation/value range of 0.5 to 1.0
Is there a good way of achieving this or do I need to stick to the simple multiplication?
if you want to use Attribute Expression you can use something like this
hsvtorgb(rgbtohsv(self)+value)
and then the value will represent offset in H, S, V (so start with 0,0,0 and add to corresponding channel as needed)
or this
hsvtorgb(rgbtohsv(self)*value)
and then the value will represent scale factor of H, S, V  (so start with 1,1,1 and add to corresponding channel as needed)
