Requiem Posted August 31, 2019 Share Posted August 31, 2019 Hello everyone, rookie here... I’m trying to get a point group from whose mutual normal angle are less than let’s say 45 degree on this geometry (to be more clear, something like occlusion effect). Now I shrink the point to this area to prevent the calculation running on all the points, but I don’t know how to go further. And I must keep this geometry intact not divide it into 2 spheres. Please anyone could enlight me a bit? Tons of thanks. Quote Link to comment Share on other sites More sharing options...
catchyid Posted September 1, 2019 Share Posted September 1, 2019 I don't entirely understand the question, but here are some pointers that might help you: -you need have points normal computed first (just in case if they don't exist in the first place), you can use "Normal" node to do that, so after you load the geo, use "convert" node if needed (eg. to unpack them), then "Normal" node (make sure it's being set to point and not vertex)--> now you have normal attributes on each point -when you use pcopen : I remember there are different ways to use this function, look for the one that returns a list of point index(es), so the result should be logically similar to this : current point has 7 points near it and their indices are [45,64,...] -Now, use these indices to get the normal of each point, a vex could should be like vector other_normal = point(geoself(),"N",indices)...ok that is a little bit short description! the idea is to loop over each index and use point vex function to get its normal -Then, for each normal you return use use dot product to compute the cosine angle (make sure that normals have unit length first), then have a test like if dot()<cos(45) flag your point (you can color them or add them to a group) Okay, there are so many fill in blanks in the above steps I know! they are just pointers. BTW, this is a manual way, I don't remember having a sop node that does that automatically! good luck Quote Link to comment Share on other sites More sharing options...
