kaffee, junge Posted September 5, 2019 Share Posted September 5, 2019 Hi all, I can not get my vellum sim to use an updated restscale attribute. It is animated on sop level (see image 1) and merged into the sim in a sopsolver with Data Name set to 'ConstraintGeometry' (see image 2). The animated attribute is in the sim, but it is not used. I attached a simple example .hip. vellum_restscale_import.hiplc Quote Link to comment Share on other sites More sharing options...
davidkvien Posted September 6, 2019 Share Posted September 6, 2019 Had a go at fixing it for you, when working with vellum constraints you have to work with primitive attributes vellum_restscale_import.hiplc Quote Link to comment Share on other sites More sharing options...
kaffee, junge Posted September 9, 2019 Author Share Posted September 9, 2019 On 9/6/2019 at 5:50 AM, davidkvien said: Had a go at fixing it for you, when working with vellum constraints you have to work with primitive attributes vellum_restscale_import.hiplc Awesome, thanks davidkvien, this works! Quote Link to comment Share on other sites More sharing options...
