lazza79 3 Posted September 6, 2019 Hi Guys, In my scene an object comes out of the ocean. I am trying to use the "guided ocean layer" for that but I have a strange issue while I'm trying to simulate with lower particle separation. Basically, my flip tank is pretty small (2 by 2) with a boundary layer of 0.25 in any direction. The issue I am having is a sort of vertical jitter of the water. In order to try to understand the root of the problem, I went back to an empty scene, created the "guided ocean" from the shelf and updated it with my tank size and the particle separation I need (0.003) I already tried to have a bigger tank (around 5 by 4) and a slightly thicker layer of water but without a success. I am loosing my mind here, did any of you had a similar issue? This is the result I have after 7 frames of sim. I posted this on SideFX forum as well... guidedOceanTest.hip Share this post Link to post Share on other sites
