Using attribute for Smooth Strength
JoeFly
Hiho,
I have been going though old Entagma tutorials, including Voronoi patterns.
To get a better fit between the Areas and the grid I am trying to adapt the smooth according to the areas size of the shapes. biiger area -> more smooth strength.
So I created a measure node, got the attribute on the primitive and then tried the simple @area on the strength attribute ... And doesn't work. Tried to promote the attribute to the points to see if that helps, but no...
OrganicVoronoiPatterns_01_od.hipnc
So if I blur the attributes, how is that actually going to help me to get to different smoothing? The attribute values are right, but I can't use it for strength since he function only allows 'global'variable. E.G. $FF would work.
Or do you mean I should use the attribute blur directly on P.xyz instead of using smooth?
I could group the primitives by @area and then use smooth values by group. Maybe a foreach primitive but wasn't able to get that working properly either.
Expand
yes, this
you could also use smooth and then blend the original and smoothed version by attribute
OrganicVoronoiPatterns_01_od_mod.hipnc
Edited by anim
