Maya Paint Effects To Houdini
ptakun
Script export Paint Effects from Maya to Houdini.
It wasn't widely tested so it might be imperfect;)
INSTALLATION:
Unpack and copy it to a current Maya project to "mel" directory.
When Maya is running write "petoh" in the console.
Make a paint effect and press GO!
In the output directory there should appear a geo file.
Open this file through the node "file" in Houdini.
Rules:
If you need to divide the paint effect into groups use node "partition" and write "$TUBETYPE" in rule.
The attribute Tubetype means: 0 branch, 1 twig, 2 leaf, 3 flower.
Script is slow when there is a lot of elements of the same type in one shape, like grass for example.
For Windows users!
You have to install Python: http://www.python.org/download/
When it's done go to Control Panel/system/Advanced and set Environment Variables
and add "C:\Python24;" to the path.
If you need Python source code please conntact me by e-mail.
Have fun :afro:
http://lizard.neostrada.pl/PeToH.zip
Example pictures (mantra):
Edited by ptakun
  • 9 years later...
