Delete by highest attribute procedurally
hampuseh
Greetings!
I have a system that creates an x amount of layers, I also apply a integer attribute value to each layer. 0-x
For example I may have done a 10 layer thing. which will give me 0-9 attribute.
My question is; How do I procedurally always delete the last layer with the highest attribute value?
Easiest way is to promote your attribute to detail, set to maximum - set the new name to eg max_layer and don't delete original attribute -  then do something like the following in a wrangle: [assuming it's a prim integer attribute called 'layer', set the wrangle to run over prims]
if(i@layer == detail(0, "max_layer", 0)) removeprim(0, @primnum, 1);
