gemini Posted September 19, 2019 Share Posted September 19, 2019 Hi, I would simply ceate a script which creates lock file when a hip is opened for the reason more users should not overwrite their scenes. The lock file should be deleted when a new hip is about to open. So i created a hip event in my scene and check which event is fired (i check the opening hip name). My problem is that I can not fire an event before the new hip is opened ( to clear the lock file ) the event always shows the opened hip not the hip which is being closed. Any idea ? thx!!! G My scripts: ---Registering the event----- hipFileEvent_script = """ def hipFileEventsFired( event_type): import houdini.illessz.events as ev reload( ev) ev.hipFileEvents( event_type) """ hou.setSessionModuleSource( hipFileEvent_script ) hou.hipFile.addEventCallback( hou.session.hipFileEventsFired) ---- The event ---- def hipFileEvents( event_type): # print kwargs if event_type == hou.hipFileEventType.BeforeClear: if not hou.hipFile.isLoadingHipFile() and not hou.hipFile.name()=='untitled.hip': print 'clear event %s' % hou.hipFile.name() else: # print 'clear ?' pass print event_type, hou.hipFile.name() if event_type == hou.hipFileEventType.BeforeLoad: print 'before load event %s' % hou.hipFile.name() # hou.hipFile.removeEventCallback( hou.session.hipFileEventsFired) Quote Link to comment Share on other sites More sharing options...
