Heightfields
HopperAE
Hey there!
Okay so I have got a grasp of how a heightfield works but what I am trying to do is confusing me.
I have the sole of a shoe and on one surface I want it to have the heightfield on. How do I merge the heightfield with the surface? I have used the project node but I still get the square.
I also used attributes from volume and then a point wrangle to transfer the height to the Y position but It affects the whole of the geo.
I need help!
Mountain_Duality_Sole.hip
2 hours ago, HopperAE said:
Hey there!
I need help!
Hi Andrew,
Could you repost your hip file, with a stash sop after your file node (and stash input before saving of course), or just freezing your file node so that we can understand what you are doing ?
Without the geo, it is hard to help you...
Hey,
Not sure I understood completely what you wanted to achieve, so here is a file with my interpretation :-)
It would probably requires the mountain to fade around the border of the sole to have a better integration.
I have used Boolean to achieve this. I let you play with it.
Hope this helps
Mountain_Duality_Sole_help_v2.hip
