Get operator name to create hda
An_pi
Hi.
After we install a HDA like this
hou.hda.installFile('hda_path.hda')
how is it possible to get the hda's operator name, so we can "create" it? The installFile function does not return anything...
hou.node("/obj").createNode("???")
The name is the one you set when you create the .hda: The recommended syntax is NameSpace::HdaName::Version, see the docs for more info https://www.sidefx.com/docs/houdini/assets/namespaces.html
Hda_Name_Example.jpg.05649c31c4b580224f09005204221b8f.jpgHda_Name_Syntax.jpg.c4b8b9784816a199ee7613c0a30fca21.jpg
You can also get the .hda's name via the node.type().name() function. For example:
hou.node("/obj/geo/custom_hda/").type().name()
For the measure node it returns: 'measure::2.0'
To create a specific version of a node you can then type:
 hou.node("/obj/geo/").createNode("NameSpace::HdaName::1.1")
Edited by LucaScheller
