Cloth sim with thickness, best practice
bobbybob
Hi
When simulation cloth I often think that adding some thickness to the cloth looks much better then just rendering a flat plane.
But what is best practices when adding thickness? To extrude the plane before simulating and adding load on the simulation, or adding it afterwards?
I am asking this because I am having a hard time controlling uvs, intersections and adding bevel to the plane after its simulated, because it is in constant change...
There's a thickness parameter on the cloth constraint node that should do the trick. The idea is that you model your cloth geo as a 2d surface, and then use it to deform hero cloth geometry after the fact
  • Thanks 1
