SOLVED Follow path issues
FR3D
I can't make anything follow path correctly, it simply doesnt work or when it works(with a camera) i cannot keyframe the position parameter
On null nodes there is no position parameter either
What am i missing?
EDIT: Thanks to MiesnerMedia
1) Go inside the object you want to constraint to a path
2) create a "constraint (chop network)", go inside and add a path node.
3) select your path object in the SOP path parameter
Edited by FR3D
  • 2 years later...
Trying to have a null follow a path, but nothing does it.... Oh man. And indeed any idiot can do that in any other package... but nah, Houdini just had to make it more complicated. FOllow constraints is applied, but the null won't follow.
Edited by Adriano
