philpappas Posted October 22, 2019 Share Posted October 22, 2019 Hello, i think this will be simple for someone more experienced. i have two vector primitive attributes and i want to write them in a text file so-------> v1.x, v1.y v1.z, n1.x, n1.y ,n1.z , v2.x, v2.y v2.z, ....etc for each primitive this is how far i am now ############# READ ATTRIBUTES ###################### for prim in geo.prims() : pos = hou.Vector3(prim.attribValue('pos')) dir = hou.Vector3(prim.attribValue('dir')) data = str(pos) + "," + str(dir) ############# WRITE TO TEXT FILE ###################### myfile = '$HIP/lattice.txt' with open(myfile, 'w') as f: for item in data: f.write("%s\n" % item) spits out this nonsense, splits every character to a new line [ - 1 7 5 2 , - 1 1 9 . 0 3 , 1 4 6 4 ] , [ 0 , 3 0 . 9 0 1 4 , 0 ] Quote Link to comment Share on other sites More sharing options...
jeremiah Posted October 23, 2019 Share Posted October 23, 2019 5 hours ago, philpappas said: for prim in geo.prims() : pos = hou.Vector3(prim.attribValue('pos')) dir = hou.Vector3(prim.attribValue('dir')) data = str(pos) + "," + str(dir) Not sure if these lines are working, but it seems to me that the value of "data" would be a string. Therefore, when you loop through "data", "item" would be each characters in the string. Hope I could be misunderstanding.. Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted October 23, 2019 Share Posted October 23, 2019 import hou import numpy as np geo = hou.node('/obj/geo1/torus').geometry() # Read the attributes into numpy arrays pos_array = np.frombuffer(geo.primFloatAttribValuesAsString('pos'), dtype=np.float32) dir_array = np.frombuffer(geo.primFloatAttribValuesAsString('dir'), dtype=np.float32) # Split the array by 3 pos_array = np.array_split(pos_array, pos_array.size/3) dir_array = np.array_split(dir_array, dir_array.size/3) # Stack the arrays (similar to python zip()) stack = np.column_stack((pos_array, dir_array)) # Make a single continuios array of form pos.x pos.y pos.z dir.x dir.y dir.z final = stack.flatten() # Save to a file with float precision = 3 np.savetxt('c:/temp/foo.txt', final, fmt='%.3f', newline=' ') If you need speeeeeeeed 3 Quote Link to comment Share on other sites More sharing options...
philpappas Posted October 29, 2019 Author Share Posted October 29, 2019 On 10/23/2019 at 7:04 AM, Stalkerx777 said: If you need speeeeeeeed thanks a lot, it works (not so fast though if you have thousands of values ) import hou import numpy as np node = hou.pwd() # get the current node geo = node.geometry() #get geometry of node # Read the attributes into numpy arrays pos_array = np.frombuffer(geo.pointFloatAttribValuesAsString('pos'), dtype=np.float32) dir_array = np.frombuffer(geo.pointFloatAttribValuesAsString('dir'), dtype=np.float32) i read the point attributes directly from the python node, absolute paths wont help a lot because i'm working in an asset. i also found this blog and the code takes about the same time to write the text file. http://astroukoff.blogspot.com/2018/05/data-from-houdini-to-unity-via-text-file.html this is the code i used (one attribute at a time though): node = hou.pwd() # get the current node geo = node.geometry() #get geometry of node myTxt = file("$HIP/POSITION.txt", "w") #create file, w = write mode for point in geo.points(): #iterate through each geo point pos = point.attribValue("pos") #save position in a pos var s = str(pos) #write position to s string myTxt.write(s) #write s string into a file myTxt.close() Quote Link to comment Share on other sites More sharing options...
