Pose Library Captures Wrong Data
MrVelocities
Hello everyone,
(This is copied from my post at Sidefx's Forum: https://www.sidefx.com/forum/topic/69881/)
I have created a rig (and character). I'm trying to use the Pose Library to save my walk-cylce and other animations.
Sadly the captured data is all wrong. Parameters like the FK/IK Sliders in my HDA get captured wrong. Several Sliders that don't have any values for some reason get all assignes values.
I feel like it tries to capture more than the parameters of my HDA.
I have already tried the different capture settings from the Pose Library. It only works when I bake the keyframes, but that would be problematic to work with.
I'm on Windows 10 with Version 17.5.391
I sometimes get these Warnings in the Console:
Qt Warn: QSortFilterProxyModel: invalid inserted rows reported by source model
Qt Warn: QWindowsContext::windowsProc: No Qt Window found for event 0x1c (WM_ACTIVATEAPP), hwnd=0x0x70070.
Qt Warn: QWindowsContext::windowsProc: No Qt Window found for event 0x1c (WM_ACTIVATEAPP), hwnd=0x0x3100be.
I attached a file with the animated bones. Thank you all very much!
(Since this is my first rig in Houdini, I also appreciate every other improvement you might want to add)
Rig_Sharable.hiplc
