Vellum hair colliding with RBD Packed Object
ceci
I've managed to make vellum hair interact or at least collide with an RBD Object. But it does not work with an RBD Packed Object. vellum_RBD.thumb.jpg.54b423f7c911a126a5ac0018f326c07f.jpg
Can vellum not read the geometry?
Is this a lost cause?
Thanks,
Cecilia
I think, you have to repack the pieces before the sim using repack fragments option, but I've never found the solution to the other problem which is the huge collision padding between the packed objects and the vellum.
