isah_voodoo Posted October 29, 2019 Share Posted October 29, 2019 I am trying to randomly translate on the y axis using a for loop. I have successfully randomized the color but for some reason I can't move them upwards. int i=0; vector rand=rand(@class*234.234); f@randY=fit01(rand(@id*234.234),2, 12); for(i; i<10; i+=1){ v@Cd=rand; @P.y=@randY; } What am I doing wrong here? translate_forloop.hipnc Quote Link to comment Share on other sites More sharing options...
toadstorm Posted October 29, 2019 Share Posted October 29, 2019 There's a couple of things here you need to fix. First, a Wrangle, unless it's in Detail mode, is inherently a kind of for-each loop that runs in parallel. So if you're just trying to bump each primitive up by a random amount, you don't need a for loop in here; the wrangle itself will generate a new random value per id. Second, the @P attribute of a primitive is only a sort of pseudo-attribute; it's not writeable the way the point attribute @P is. You'll want to edit point positions in a point wrangle instead. If you want to move each box randomly upwards, you have two good options: you can move the template points before the Copy SOP, or you can pack and instance the boxes and then move them in a Point Wrangle, since a packed object effectively works like a point. 1 Quote Link to comment Share on other sites More sharing options...
isah_voodoo Posted October 30, 2019 Author Share Posted October 30, 2019 @toadstormthank you for the tips. I got it working Quote Link to comment Share on other sites More sharing options...
