tmac2k7 Posted October 29, 2019 Share Posted October 29, 2019 Newbie alert. Having trouble figuring out how to select certain points procedurally on the roof system. I would like to group specific points then ray them onto bounding region to get the attached desired look. RoofCornerproblem.hiplc Quote Link to comment Share on other sites More sharing options...
tmac2k7 Posted October 30, 2019 Author Share Posted October 30, 2019 So managed to work on it some more and got close to the desired out come. Here is the results. RoofCornerproblem2.hiplc Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted October 31, 2019 Share Posted October 31, 2019 Hi tmac, you can move the internal point of a triangle to the border by applying the average position of its two other points to it: // in a primitive wrangle if(primvertexcount(0, i@primnum) == 3){ // make sure it's a triangle int pts[] = primpoints(0, i@primnum); // collect all points of the triangle vector pos = 0.0; // set a initial position value for summing up the other two points positions later int pt_move = -1; // set a initial point number for the yet unknown inner point foreach(int pt; pts){ // run over all points of this triangle if(inpointgroup(0, 'outer', pt) == 1){ // ask whether this point is part of the outer group pos += point(0, 'P', pt); // add its position to the position sum from line 3 } else{ // if the currently processed point is not part of the outer border.. pt_move = pt; // .. define it as the inner point thats supposed to be moved.. } } vector pos_avg = pos / 2.0; // .. to the average position of the other two points. setpointattrib(0, 'P', pt_move, pos_avg, 'set'); // apply the new position to the inner point. } Rising the roof can be done without promoting the polyframe`s egdedist attribute, simply by calling the vertex attribute within a point wrangle: v@P.y += vertex(0, 'edgedist', i@vtxnum); roof.hipnc 2 2 Quote Link to comment Share on other sites More sharing options...
tmac2k7 Posted October 31, 2019 Author Share Posted October 31, 2019 Waw just great. Can not thank you enough for taking the time to look at it. You turned 17 nodes into 3. Much appreciation. 1 Quote Link to comment Share on other sites More sharing options...
tmac2k7 Posted October 31, 2019 Author Share Posted October 31, 2019 Apologies for the inconvenience and my lack of knowledge of vex. Just one last query regarding a point with four connecting edges that is causing an error. Would like it deselected from the tri points as it distorts the roof shape. I have included error scene. roof (1).hipnc Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted October 31, 2019 Share Posted October 31, 2019 Never mind, you can check if the point has three neighbors, otherwise it does not move the point. if(primvertexcount(0, i@primnum) == 3){ int pts[] = primpoints(0, i@primnum); vector pos = 0.0; int pt_move = -1; foreach(int pt; pts){ if(inpointgroup(0, 'outer', pt) == 1){ pos += point(0, 'P', pt); } else{ pt_move = pt; } } if( neighbourcount(0, pt_move) == 3){ vector pos_avg = pos * chf('shape'); setpointattrib(0, 'P', pt_move, pos_avg, 'set'); } } Quote Link to comment Share on other sites More sharing options...
tmac2k7 Posted October 31, 2019 Author Share Posted October 31, 2019 Thank you so much for your help. Ill stop bothering you now. Much appreciation. 1 Quote Link to comment Share on other sites More sharing options...
