Mixamo Texture Maps and Principled Shader
Hello! Houdini beginner here.
I've downloaded some character and animation model from mixamo.com, but I'm having trouble plugging in the texture maps to the principled shader.
I currently have the diffuse map plugged into Base Color, specular map plugged into Reflectivity, and normal map into Base under Base&Normal tab. And I'm getting this weird result. How can I fix this?
Thank you in advance for taking a look at it!
-Y
