How can I render a COP as background of camera?
Masoud
If you're using mantra you can add the same expression in the background display options of the renderview. You can open these by pressing the "d" key in the render view. For other render engines it depends on the support of COP networks and the COP syntax.
Edited by LucaScheller
On 11/12/2019 at 7:32 PM, ejr32123 said:
why? Also, why not just add it in post? I wonder if the cop not rendering is a bug :(
In final step, I'll use post to composite background, but when I need to test my scene, I would like to see the background in Houdini renders.
