Quickmark: CTRL + [Number] hotkeys
Looks like when I want to set quickmark to certain parts in my node graph, CTRL+1, CTRL+2, CTRL+4 works but CTRL+3 does not seem to work.
I don't have any shortcut saved to this key combination, so I'm wondering, if this is the expected behavior in houdini 17.5 somehow?
Edited by monomind
The Ctrl+3 should work the same as the other numbers. This is how the default settings should look:
You may also check this file, if there really is not any override. Or temporarily rename the file to return the hotkeys to the default state, and restart Houdini to see if it helps:
C:\Users\ ... \houdini17.5\Houdini.keymap.overrides
