nomad Posted August 10, 2006 Share Posted August 10, 2006 hello. in houdini 5 (or 6) when i input the force node to a particle node (input 3 :force) the blue handles has appearing but in houdini 8 there is no blue handles in this case. How can i make it visible? Quote Link to comment Share on other sites More sharing options...
Jason Posted August 10, 2006 Share Posted August 10, 2006 There could be 3 things wrong in order of likelihood (as I'm not sure that anything has changed in that regard since Houdini 6) */ You're forgetting to set the TemplateFlag on the POP with the force. Just try setting all 3 node flags just in case. */ You're accidentally not in a POPs 3DViewportPane but are viewing the results of a POP network through a SOP or Object ViewerPane. */ Your DisplayOptions are not set up to show templated objects. Quote Link to comment Share on other sites More sharing options...
nomad Posted August 10, 2006 Author Share Posted August 10, 2006 thank you Jason, it seems, that I did not explain this problem exactly in attach there are two screenshots : the scene in houdini 5 and the same scene in houdini 8 the blue margins of force influence don't appear Quote Link to comment Share on other sites More sharing options...
Jason Posted August 10, 2006 Share Posted August 10, 2006 Ah; the Particle SOP! Sorry! Hmm, yeah; this seems like it might be a bug. Could you report it here: http://www.sidefx.com/index.php?option=com...ewforum&f=4 ...and someone from SESI might get around to confirming it. Feel free to link back to this forum to refer to the images. Quote Link to comment Share on other sites More sharing options...
nomad Posted August 11, 2006 Author Share Posted August 11, 2006 truly this is a bug Quote Link to comment Share on other sites More sharing options...
Jason Posted August 11, 2006 Share Posted August 11, 2006 truly this is a bug At least its not your fault;) Dont be sad, sometimes they fix a thing like this in minutes, sometimes months. You'll know tomorrow if you check the development journals because if they fixed it already, you'll get a new build in a week and all will be well. Quote Link to comment Share on other sites More sharing options...
