Librarian Posted November 24, 2019 Share Posted November 24, 2019 I like this https://www.behance.net/gallery/33839482/Point-Render How to achieve this shader Brush effect? Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 25, 2019 Author Share Posted November 25, 2019 Here on the forum, you can find everything just to learn to combine /close. td_cross_2.hipnc (file from 2004) reading from points attribute Qfields FUN #define PI 3.1415926535897931 #pragma label Theta "Maximum Theta" #pragma label spread "Overall Spread" #pragma label DATA "Data Points" #pragma label kd "Diffuse" #pragma label ks "Specular" #pragma label bump "Bump" surface qrotation_field ( float Theta = 2.0, spread = 3, kd = 1, ks = 0.5, bump = 0.1; string DATA = "$HIP/../VEX/Reading-Data-Points/_datapoints.bgeo.sc") { float d, Np, theta, pFratt, factor, pspread; vector _P, pP, axis, pVratt; vector4 Q; string group; _P = ptransform("space:camera", "space:world", P); theta = snoise(_P + 0.9, 1, 0.75, 1)*4.5; axis = snoise(_P + 0.05, 1, 0.05, 1); Q = quaternion(theta, axis); _P = qrotate(Q, _P); for(int g = 0; g < 2; g++){ group = concat("group", itoa(g)); int p[] = expandpointgroup(DATA, group); Np = len(p); factor = g + 1; for (int i = 0; i < Np; i++){ pP = point(DATA, "P", p[i]); axis = point(DATA, "N", p[i]); pFratt = point(DATA, "fratt", p[i]); pVratt = point(DATA, "vratt", p[i]); pspread = pFratt*spread/factor; d = distance2(pP, _P); d = exp(-d*d/pspread); theta = 2*PI*(pFratt*2 - 1)*d*Theta/factor; Q = quaternion(theta, axis); _P = qrotate(Q, _P - pP) + pP; } } vector outColor = snoise(_P*0.25, 1, 0.25, 1); vector Nn = normalize(computenormal(P + min(outColor)*bump, N, Ng)); vector diff = diffuse(Nn)*outColor*dot(normalize(-I), N); vector spec = specular(Nn, normalize(-I), fit01(min(outColor), 0.5, 0.1))*0.1; spec += specular(N, normalize(-I), 0.05); Cf = diff*kd + spec*ks; } 1 Quote Link to comment Share on other sites More sharing options...
jimeng20 Posted November 25, 2019 Share Posted November 25, 2019 Interesting topic, thanks for sharing! Quote Link to comment Share on other sites More sharing options...
