Skipping node if empty
hampuseh
Greetings!
I am working on a tool to generate buildings.
I have different blast nodes within the tool to separate primitives to groups before I pack and instance them.
However, some blast nodes will be empty since not all buildings have the same primitive groups. So what happens is that even if a blast node contains nothing the pack node still packs the empty node and creates a instance point(containing nothing). This creates a render error with redshift.
My question is; is there a way to look at node and if it doesn't contain any points/primitves then the network just stops or gets output to a null?
