alutaroma Posted November 27, 2019 Share Posted November 27, 2019 Hi. Is any variable that stores information about wire existence in shader editor? I mean, I need the variable that is 1 when the texture is connected to base_color slot and 0 when there is not. What I'm trying to achieve is the arnold texture preview in the viewport. I created a texture tag in the parameter interface and it works but I want to the “use Texture” toggle be connected with the variable I mentioned. Also, is it possible to get the name of the node that is connected to the slot? In my case, the result would be “image1”. If not, is any different way? Thanks. Quote Link to comment Share on other sites More sharing options...
