Qtvr
sibarrick
Does anyone here know of any software for making QuickTime VR movies that is scriptable?
We currently use VR worx but the scripting is a joke and doesn't let you batch anything. All images have to be loaded by hand which takes forever.
If anyone has any knowledge on this subject I would be very grateful, ta.
Please check this: Quest3D and Virtools
cheers, Quicktime VR is perhaps badly named. It's not VR at all really, not in the sense of those tools you link to. A QTVR object is just a set of frames that can be built into a movie that the user can interact with using a mouse. It allows you to tumble and spin an object but all done as pre-rendered images not using any 3d code at all.
Ok, my last try :)
The only other software I know that does this is Strata.
File In/Out Features - Quicktime VR (out)
Strata 3D CX outputs both QuickTime VR panoramas and QuickTime VR objects. The QuickTime VR Panorama simulates an actual camera with a 360
  • 3 weeks later...
love RealViz Stitcher,
I was one of the lucky ones who was in HDR class at SCAD.
very cool stuff..
i'll go look over my notes and see what other software ther is though will bet back in a bit.
ther are also some really neat plugins for photoshop to work with it.. if you are useing a fisheye lens or need to unwrap an image to use .
There's a ton of software for making panaroma's but i'm only interested in vr objects. This is somewhat different, and i'm only looking for commandline tools for batch processing them. I think its actually a fruitless search, as far as I can tell from my now extensive searches no-one has written such a piece of software :(
Thanks for all the suggestions though, maybe a passing nomadic programmer will read this and decide the world needs a commandline vr object maker....
From google, I found this page http://www.edb.utexas.edu/teachnet/qtvr/QTVRObjectNeeds.htm which suggested that the QuickTime developers kit contains a tool which can convert a QuickTime movie into a QTVR object.
A bit more searching and I found this:
http://developer.apple.com/samplecode/vrma...ject/index.html
It comes with source so with some hacking, you can probably come up with a command line tool that will take a bunch of images and create a command line QTVR tool.
That's true, but as usual I want more! I need to create an Vr object with 3 dimensions. Rotation, Layering and Animation so its a little more complex than just making a linear movie. I couldn't see how the tools they provide would handle that. I know its possible because I can do it in VR worxs.
From what I've read, it sounds like it just relies on the fact that your linear QT movie is taken with certain viewpoints (every X degrees rotated). So it just takes the images from that and creates it into the QTVR object. Have you tried running the example from Apple?
I haven't, i'll try it if I get time, but that isn't my understanding of it. Yes it is true for a simple rotation as you describe but when you give it two directions of rotation the movie is 2 dimensional and when you give it layers as well then it becomes 3 dimensional. Now that might be encoded as a single linear stream, but is there anywhere in that code that you can specify the dimensions of the other rotations and layers? If not it will treat the whole thing as if it were a simple one dimensional rotation and you would be able to navigate around the object correctly.
I'm not really sure if I remember correctly but I used to play with swift 3d and some other softwares for making 3d flash animation. It works as a standalone package or as a plugin to 3d softwares. And... not really sure but your question has reminded me, that swift3d got a QTVR export option. Swift 3d or one of its competitor. I tried few of them in very limited amount of time for some particular project long, long time ago, so sorry or imprecision! Hope you'll find the answer!
cheers,
SY.
