Alfred_dupont Posted December 4, 2019 Share Posted December 4, 2019 Hello, I'm running through an issue since I'm still learning and some points remain uncertain, I need some tips and advices for this. I have a setting with a vellum object, I'm using a dopnetwork instead of a vellumsolver. Inside my dopnetwork I have a source node to generate multiples objects over time, eveything is fine, but my question is, can I use a pointdeform with such configuration? it seems that it doesn't work for an unknown reason. I already used a point deform while using a dopnet and it's working great, so I can't figure out where my issue is. How to say to the pointdeform it has to take the information from the source node inside the dopnet? hope it's clear, Thanks Quote Link to comment Share on other sites More sharing options...
