Point Deform and Dopnet
Hello,
I'm running through an issue since I'm still learning and some points remain uncertain, I need some tips and advices for this.
I have a setting with a vellum object, I'm using a dopnetwork instead of a vellumsolver. Inside my dopnetwork I have a source node to generate multiples objects over time,
eveything is fine, but my question is, can I use a pointdeform with such configuration?
it seems that it doesn't work for an unknown reason.
I already used a point deform while using a dopnet and it's working great, so I can't figure out where my issue is.
How to say to the pointdeform it has to take the information from the source node inside the dopnet?
hope it's clear,
Thanks
