josfella Posted December 5, 2019 Share Posted December 5, 2019 Hi, I'm trying to create polylines between two groups of points, but not use the same 'destination' point twice. The points are divided into two groups (upper and lower) and I'm using a point wrangle (with Group set to 'upper') to create the polylines: int nrpt = nearpoint(0, 'lower', @P); addprim(0, 'polyline', @ptnum, nrpt); setpointgroup(0, 'lower', nrpt, 0); By removing the destination point (nrpt) from the 'lower' point group I was hoping that nearpoint() wouldn't return that point again. It creates the polylines and removes the destination point from the point group, but it still uses that point again in the next iteration. I thought this might be because the wrangle is multi-threaded and so the call to setpointgroup() is too late (the other threads have already done their thing) so I tried using a Detail wrangle instead: int npts = npoints(0); for(int i = 0; i < npts; i++) { if (inpointgroup(0, 'upper', i)) { int nrpt = nearpoint(0, 'lower', point(0, 'P', i)); addprim(0, 'polyline', i, nrpt); setpointgroup(0, 'lower', nrpt, 0); } } Unfortunately I get the same result Anyone got any ideas? test .hip attached... polyline_connect.hipnc Quote Link to comment Share on other sites More sharing options...
Librarian Posted December 5, 2019 Share Posted December 5, 2019 Just play with 1 inp and 2 inp on Wrangle ( code found here on Odforce). int drawLine(vector f; vector t){ int base=addpoint(0,f); int to=addpoint(0,t); int line=addprim(0,"polyline",base,to); return line; } //----------------------------- int read=0; if(npoints(1)>0){ read=1; } int maxLines=chi("maxLineCount"); float minLen=chf("minLineLength"); int pts[]=pcfind(read,"P",v@P,chf("maxLineLength"),chi("maxFindCount")); int randomConnect=chi("randomConnect"); int keepPointCount=min(1, max(0,chi("keepPointCount"))); int runner=0; vector curPos; int pt; if(randomConnect == 0){ for(int x=0; x<len(pts);++x){ pt=pts[x]; if(runner > maxLines){ break; } curPos=attrib(read,"point", "P", pt); if(length(curPos-v@P)>minLen && (@ptnum<pt || read)){ if(keepPointCount){ int to=pt; if(read){ to=addpoint(0,curPos); } addprim(0,"polyline",@ptnum,to); }else{ drawLine(v@P,curPos); } runner++; } } }else{ int l=len(pts); float fl=float(l); int rander=pts[int(random(@ptnum*fl+randomConnect)*fl*fl) % l]; curPos=attrib(read,"point", "P", rander); if(keepPointCount){ int to=rander; if(read){ to=addpoint(0,curPos); } addprim(0,"polyline",@ptnum,to); }else{ drawLine(v@P,curPos); } } Quote Link to comment Share on other sites More sharing options...
josfella Posted December 6, 2019 Author Share Posted December 6, 2019 Thanks @Librarian, but this seems to give me the same results For each point in the upper group, I want to draw a line to the nearest point in the lower group that doesn't already have a line connecting it. I'm probably missing something, but I can't see an 'already connected' check in the code you posted? Quote Link to comment Share on other sites More sharing options...
josfella Posted December 6, 2019 Author Share Posted December 6, 2019 Fixed it! In a Detail wrangle: int npts = npoints(0); int connected[]; //for each point for(int i = 0; i < npts; i++) { if (inpointgroup(0, 'upper', i)) { //find all nearest lower pts int nrpts[] = nearpoints(0, 'lower', point(0, 'P', i), 1000, 1000); //loop through lower points for(int j = 0; j < len(nrpts); j++) { //if not already connected if(connected[nrpts[j]] != 1){ addprim(0, 'polyline', i, nrpts[j]); connected[nrpts[j]]=1; break; } } } } By creating a new array to store the 'connectedness' of each point I could remove the setpointgroup() logic. Makes sense now I think about it - the wrangle was pulling in the nearpoints (and their group data) from upstream each iteration! Quote Link to comment Share on other sites More sharing options...
