selective bevel problem
davidyannick
Hey, when I load your file it doesn't seem to be working properly. However, in your switch node, you're using @class%2==0. As far as I know you can't use attributes in a switch like that. Try getting the attribute like this: prim("../foreach_begin2", 0, "class", 0) % 2
https://www.sidefx.com/docs/houdini/expressions/prim.html
Hope it works!
Hope it works!
it works thanks :)
