gerardocastellanos
vector on detail (VEX)
Hi everybody
I want to use the "detail" function as an expression in a node parameter to read a vector component.
detail("../sourceData","color.r",0)
but it does not work. I tried "color.0", same result
when I use just "color", it reads something, an average could be, anyway I just want to read one component of a vector value.
how can I do that?
thanks you.
Share this post
Link to post
Hi Gerardo,
you should read the whole vector and then get its component.
Also, if the "../sourceData" is meant to be path to a node, then it is wrong. You should not use relative path to specify the geometry. Here are the methods:
https://www.sidefx.com/docs/houdini/io/op_syntax.html
Or here, read my post:
Then, after you fix your path ... here are two methods to get the indexed component:
vector color = detail(0, "color", 0);
@color_r = color[0];           // first method
@color_r = getcomp(color,0);   // second method
Edited by ikoon
Share this post
Link to post
Thanks a lot for your answer
but I am working in a parameter of a node, I can not write multiple lines code.
and I am using relative paths because it is a asset, and I want to re-use it in others places and scenes.
thanks you again
Share this post
Link to post
Hi, in the title of the topic, you defined it as a VEX. If you are typing into a parm, then you are using probably a Hscript Expression Language, not VEX (it could be python as well). I assume that you have an Expression and this should work:
detail("../sourceData","color",0)
The detail() expression has different syntax then detail() vex function, and the third argument is attrib_index (or in other words, third argument is 0 for color[0], 1 is for color[1] etc.)
https://www.sidefx.com/docs/houdini/expressions/detail.html
What I wrote in previous post is related to VEX detail(), not Hscript Expression detail().
Share this post
Link to post
No problem. I hope that it works fine now.
I also want to add one thing. You can write multiple lines of code even in the parm, like this (start with RMB on the parm). Or hit Alt+E, when editing the parm:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
