Birthing particles dynamically
Tomotron89
Hi All,
I'm trying to get this setup working where I have particles that are being activated and turned on before being fed into a pop net. I'm stuck as to how i might be able to birth only each initial particle as they're activated into the popnet. I'm trying a couple of expressions in the impulse activations, but not having luck. I'm currently birthing particles at a constant rate every 5 frames, but what I would like to do is only birth once on each incoming particle. Any help would be appreciated as I'm still learning this :)
Particle_Growth_example.hiplc
