VRAY - instancing and timeoffsets
Wolrajh
Hello there,
So I'm back on a V-ray project, and I have to scatter a few impact-like VDBs. I was thinking of going the traditionnal way, getting the point cloud, adding instancepath / instancefile, with a made up string including the much needed offset. Classic, right ?
My issue is that I just can't get it to work with vray. It just renders nothing with no relevant info in the log - except "render's done".
I tried with VDB files. I tried with vrscene files, tweaking the anim_start primintrinsic. I tried with copystamp and timeshift. I even tried by linking a geo diretly into the relevant instance field.
Best I could get to render was instancing the same frame on all points. Instancepath and/or timeoffset look dead in the water.
With no access to their own forums, I'm forced to come here to ask :
How the heck are we supposed to instance from disk files or create a cloud of timeoffseted instances with Vray ?
And all of this despite the V-ray beta 1 release notes stating this :
Quote
Instancing Types
  • Instancing through Instance node
  • Light Instancing through Instance node
  • Instancing through instancepath attribute
  • Light Instancing through instancepath attribute
  • Instancing of volumetrics supported
