How to get viewport handles for created points with addpoint()
Christoph_H
you are creating static handles, which are only limited to hardcoded amount
for the example of dynamic handles created using python viewport states as mentioned above you can have a look at Rbd Constraints From Rules or PointWeld SOPs
I have to ask again for help.
I have recently started with python and therefore still have Problems.
This script is placed in the | type proberties | interactive | viewer state |:
1. By adding newer points the effect changes only if I press apply at viewer state
2. Somehow the program did not accept the relative path to the parameter. How does that work?
3.
and I haven't been able to create new handles yet
I would be interested in how a clean structure of such a script would be written
help would be great.
many thanks.
import hou
import viewerstate.utils as su
picker_folder = str(hou.evalParm('/obj/geo1/picker/folder0')) #Somehow the program did not accept the relative path to the parameter. How does that work?
pickerx = "picker"+picker_folder+"x"
pickery = "picker"+picker_folder+"y"
pickerz = "picker"+picker_folder+"z"
print(pickerx,pickery,pickerz)
#print(picker_folder)
class State(object):
    def __init__(self, state_name, scene_viewer):
        self.state_name = state_name
        self.scene_viewer = scene_viewer
        self.translate_handle = hou.Handle(self.scene_viewer, "Translate")
    def onEnter(self, kwargs):
        self.translate_handle.show(True)
    def onHandleToState(self, kwargs):
        """ Used with bound dynamic handles to implement the state
        action when a handle is modified.
        handle = kwargs["handle"]
        parms = kwargs["parms"]
        mod_parms = kwargs["mod_parms"]
        prev_parms = kwargs["prev_parms"]
        ui_event = kwargs["ui_event"]
        self.log(parms)
    def onStateToHandle(self, kwargs):
        """ Used with bound dynamic handles to implement the handle
        action when a state node parm is modified.
        node = kwargs["node"]
def createViewerStateTemplate():
    """ Mandatory entry point to create and return the viewer state
        template to register. """
    state_typename = kwargs["type"].definition().sections()["DefaultState"].contents()
    state_label = "picker"
    state_cat = hou.sopNodeTypeCategory()
    template = hou.ViewerStateTemplate(state_typename, state_label, state_cat)
    template.bindFactory(State)
    template.bindIcon(kwargs["type"].icon())
    # bind a static handle to node parameters.
    template.bindHandleStatic( "translate", "Translate",
            (pickerx, "tx"),
            (pickery, "ty"),
            (pickerz, "tz")
    return template
