Noobini Posted December 22, 2019 Share Posted December 22, 2019 (edited) HDA to create a square spiral....but you don't have to be square, change it to hexagonal (60) if you like. (no Vex required.) DL link in the tube video. (could probably tweak for angle of 120 for a triangle too...but can't be arsed). Note: if you try to bevel the corners, if divisions is ODD, the midpoint will go missing, if it is EVEN, it works. The bug appears only for multi curves that have been joined/fused together, ie. on a default grid, it works fine. I have reported this bug to SESI. Edited December 22, 2019 by Noobini Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 23, 2019 Author Share Posted December 23, 2019 usage: for resorting when the Sort just won't do it. vu_SpiralSelect.hiplc 1 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 23, 2019 Author Share Posted December 23, 2019 (edited) alright, did the triangle...probably useless...can't see how it could be practical...but for completeness sake. 90: Square 45: Oct 60: Hex 72: Pent 120: Tri Edited December 23, 2019 by Noobini Quote Link to comment Share on other sites More sharing options...
