Exclude certain points from PolyPath?
Krion
I saw on a forum post that if I want to merge a two points and have them be one primitive, I could use the PolyPath node for that, because the Fuse SOP doesn't do that. So that works now and I am very happy with that.
But now I want to exclude certain points from the PolyPath. I have put those points in a group, but the PolyPath doesn't have a group field.
Is there a way to still exclude a group of points? Or is there another SOP I could use for this?
See the scene if you want to see a quick example of the problem. I want only 'child prims' that have the same parent prim to be reconnected to one prim again.
Hope it's possible :) Thanks!
polypathgroup.hipnc
Edited by Krion
