Import Records into PopNet
CinnamonMetal
Seems like you can. By setting the pop solver to add 'impact data' instead of hit attributes. And set the Data Path and Record on the Dop Import Records node to 'Impacts'. When you're working with a new node and you're not sure exactly how to use it, always check the help documentation. In this case there was an example scene which helped a lot. https://www.sidefx.com/docs/houdini/nodes/sop/dopimportrecords.html
dop_import_records.hipnc
  • Thanks 1
