Heightfield scatter SOP, control directions.
Hi guys, im using the heightfield scatter SOP, to put some primitives at the ground.
one problem is that node dont have an option to control the direction the scattered.
the node is getting the normal of the terrain and using to directions.
my ideia was to create an arbitrary value such f@N = 0,1,0 and mi x(using slider) with the current normal terrain. still no luck at all.
https://we.tl/t-uJlDSUlnTb
  On 1/15/2020 at 2:45 PM, DaJuice said:
Uncheck 'Match Normals with Terrain". The 'Random Up' slider allows you to add some randomness back in.
Expand
STILL is there any possibility to control the orientation??
like an slider:
0 is the normal terrain
1 is the Y-UP
awesome, indeed probably it will work! ty
Edited by gangland
