Furox Posted January 16, 2020 Share Posted January 16, 2020 Hello everyone I created a campfire for a project. However, I find myself with a bounce effect at the beginning of the video. I don’t know if you have an idea ? https://youtu.be/mBwlIlFspxk Quote Link to comment Share on other sites More sharing options...
wakimsan Posted January 16, 2020 Share Posted January 16, 2020 Hi Furox, It will depend a bit on what you're after, but here's some things you could do; -Add a preroll - start your sim earlier so that it's fully developed on the first render frame. -Slowly increase fuel - you can animate the amount of fuel your solver takes in. Starting off with 0 and slowly increasing to the desired amount should reduce sudden pop/bounce. -Add some strong noise to your fuel source - it might help break up the uniform bounce at the begining. Cheers 1 Quote Link to comment Share on other sites More sharing options...
Furox Posted January 16, 2020 Author Share Posted January 16, 2020 Thank you so much for that information, it work :D!!! 1 Quote Link to comment Share on other sites More sharing options...
