shawn_kearney Posted January 17, 2020 Share Posted January 17, 2020 (edited) Is there any way to scale the ignition temperature with a field such to simulate different material combustion properties within a single pyro solver? I tried looking into how the Ignition Temperature parameter is implemented, but I only got as far as as the GAS Combustion DOP node and the trail seemed to go cold. Edited January 17, 2020 by shawn_kearney Quote Link to comment Share on other sites More sharing options...
bunker Posted January 18, 2020 Share Posted January 18, 2020 inside the GasCombustion DOP, have a look at the "temp_to_burn" node there is a "constant" parameter, that's where your ignition temperature goes. you'll have to replace that node with a custom wrangle for example... 1 Quote Link to comment Share on other sites More sharing options...
shawn_kearney Posted January 19, 2020 Author Share Posted January 19, 2020 (edited) Hi Jullian! Thank you for that. I must have overlooked the Constant param. Seems to work with a wrangle: f@burn = f@temperature - f@ignition*chf("../ignitiontemp") ; where f@ignition is the ignition temp control field imported into dop using 'copy'. Edited January 19, 2020 by shawn_kearney Quote Link to comment Share on other sites More sharing options...
