Gianluca Siciliano Posted February 6, 2020 Share Posted February 6, 2020 Hello guys, still me trying to understand how Houdini works I basically would like to calculate the delta between the points of a target geometry and a reference same topological mesh in the tangent space of this reference geometry. I quite tho do not find a mathematical way to calculate it using vex. Any idea? Thanks Quote Link to comment Share on other sites More sharing options...
Feather Posted February 7, 2020 Share Posted February 7, 2020 By tangent space do you mean along the curved surface of the geometry or literally like a tangent plane of each point on the mesh? Quote Link to comment Share on other sites More sharing options...
anim Posted February 7, 2020 Share Posted February 7, 2020 (edited) you can compute UV tangent space direction vectors on geo using Poly Frame SOP (few modes for that Texture UV gradient, Attribute Gradient, MikkT) then you can construct matrix from them and use for whatever you need you can also use Attribute Reorient SOP to apply sort of tangent space delta between 2 meshes to any vector or quaternion attribute, which may be easier that computing everything yourself, but it really depends on what you are doing Edited February 7, 2020 by anim Quote Link to comment Share on other sites More sharing options...
Gianluca Siciliano Posted February 8, 2020 Author Share Posted February 8, 2020 1 hour ago, anim said: you can compute UV tangent space direction vectors on geo using Poly Frame SOP (few modes for that Texture UV gradient, Attribute Gradient, MikkT) then you can construct matrix from them and use for whatever you need you can also use Attribute Reorient SOP to apply sort of tangent space delta between 2 meshes to any vector or quaternion attribute, which may be easier that computing everything yourself, but it really depends on what you are doing Yep this is exactly what I might need...I will try thanks. I am trying anyway to recreate the concept of tangent space blendshape like in Maya so I needed the correct way of calculating the delta between two meshes so I can then use this to update the point position of my source 1 Quote Link to comment Share on other sites More sharing options...
