Resuming a crashed flip sim via "initial state"
xer0
Hi there,
I have to resume a crashed flip simulation. I cached out the .sim files directly. My simulation crashed at $SF 60.
My question is the following: When I load $SF 50 from my cache as the initial state in the dopnet and adjust the output range, do I need to start the new output at $SF 50 or $SF 51. I would assume that $SF 51 would be correct since I load $SF 50 as the initial state and continue the solve from there. What makes me a bit nervous is that when I compare the filesizes from the crashed solve and the continued solve the sizes for corresponding frames are varying - shouldn't I get the exact same solve when continuing the simulation via loading an initial state? Am I missing something else?
Any hint much appreciated!
