Vector Field HDA bundle
diffuse.gray
The workflow for points is a bit different - since there's no equivalent to the curve framing / parallel transport, you have to make sure to define the bases (N, tangent, bitangent) yourself before passing into the format point feature node.
Here's a sample file with an arbitrary open curve, closed curve, and point feature. I also included the basic visualization setup I've been using - might turn that into a tool in its own right!
vecfieldworkflow.hiplc
